Login Error
Close
Top 4 Blade Materials for a Kitchen Ceiling Fan
by DoItYourself Staff
If you are trying to choose a new kitchen ceiling fan, or you plan to modify your existing one, you will need to choose what type of blades you would prefer. As the blades of a ceiling fan are the most visible part, it is important to think about how they will fit into the appearance of your kitchen. Because of this, giving equal consideration to all of the different fan blade materials that exist is very important, as you would not want to eliminate the best option for your kitchen by mistake.
Wood
Wood is among the most stylish options available for ceiling fan blades. Because of all of the different options available if you choose to have wooden ceiling fan blades, they can be easy to work into any room, no matter the style of decoration. Different types of wood obviously have different appearances, but there are many other options you can choose from when selecting a specific blade. For one thing, different finishes and stains on the same type of wood can result in dramatically different appearances.
However, wood can warp in heat, especially when exposed to moisture. This can cause other, secondary problems with your ceiling fan over time. For this reason, wooden ceiling fan blades are a bad idea, especially as you get closer to a source of heat. Consider using wooden ceiling fan blades in a different room of your home.
Plastic
If the appearance of wood does not interest you, plastic fan blades may be an option to consider. Whether you think no type of wood would fit into your kitchen, or you simply prefer a neater, simpler look, plastic blades are definitely an option you should look into. Plastic can come in a variety of shapes and colors, so it gives you plenty of different appearances for different situations. They are also among the easiest to decorate yourself, making them a great choice for anyone who is artistically inclined.
Additionally, plastic can shrug off moisture and humidity easily. It is also unlikely to be damaged by the heat produced in a normal kitchen. With a kitchen ceiling fan featuring plastic blades, you can easily keep air circulating without having to worry about gradual damage.
Wicker
If you are looking for a less traditional material for your kitchen ceiling fan blades, you should consider wicker. Wicker fan blades, while not an immediately obvious choice, have a unique appearance that you cannot get from any other material.
Unfortunately, wicker can be damaged by moisture and heat when they are in combination. The protective coating over wicker fan blades is particularly easy to damage.
 forum activity
