Login Error
Close
Top 4 Least Expensive Types of Roofing Materials
by DoItYourself Staff
There are many types of roofing materials available on the market today. Some of these roofing materials are very expensive to purchase and maintain while others are very reasonable. You do get what you pay for, but in the end, if the roofing materials are installed correctly, they will still last for over twenty years. The following article will list several of the cheapest types of roofing materials that you can have installed.
1. Asphalt
Out of all of the types of roofing materials available to you, the asphalt shingle is the cheapest. It will cost around $1.00 per square foot for the shingles, making it possible to do an average, single-story home for under $2,000.00. They are also the most popular on the market today. You can find these in non-organic and organic styles, with the purely organic shingles being the most expensive. Non-organic shingles are often made out of fiberglass. The asphalt shingles come in many colors, are very durable and are manufactured with an adherence to strict guidelines. They are vulnerable to ice and high winds. You can also use rolled asphalt which is rolled over the roof and then nailed in place. It does the same type of job as the shingles.
2. Metal
Metal types of roofing materials are the second least expensive at around $1.80 a square foot. They can be as much as $6.00 a square foot depending on the type of metal used. They were used decades ago, but at the time were obscenely expensive. This is because vast majorities were made from copper, lead or zinc. The types of roofing materials that comprise metal roofs today are galvanized steel, which is used in hurricane areas. Metal types of roofing materials are quick to install and also simple.
3. Wooden
Wooden roofing materials are made from red cedar, due to its resistance to the elements and insects. Cedar shingles do not decay rapidly. There are essentially 2 types of wooden shingles: shakes, which are split rather than cut, and a standard shingle, which is mechanically sawn. When using wooden types of roofing materials you need to use the shakes, as these are the best to use for roofing. Sizes also vary. These are beginning to get up in price, but are still cheaper than other types of roofing materials. Wooden shingles cost around $70.00 per square foot, but can get as high as $100.00 a square foot, depending on the manufacturer and the style of shingle.
4. Clay
The pricing for this type of shingles has a broad gap, ranging from $150.00 per square foot to $400.00 a square foot. Clay is one of the types of roofing materials that looks stunning once it is installed and can easily set a mood or finish a décor. They are also resistant to mold and decay and insects cannot penetrate them. They also will not burn and will last for decades far beyond the life of the wood they are attached to. The tiles are quite heavy which contributes in their higher cost.
 forum activity
