Login Error
Close
Top Low Voltage Led Lighting
by DoItYourself Staff
If you're looking for something to enhance the atmosphere and the ambiance of your outdoor space, look no further than low voltage LED lighting. Lights of this type make an excellent choice for any outdoor space; they provide just enough lighting to illuminate an outdoor space but don't provide so much that it will cause the yard or the side of your home to appear bathed in light when the lamps are illuminated. LED lights are better used to create a feeling or an ambiance in an area than for security purposes; still, many people opt to use them to light up the staircases outside of their front or back doors. Others use LED low voltage lights to shine on their gardens, fixtures or furniture in their yard as well. Read on for some of the top LED low voltage lighting types and options.
Candelabra Bulbs
For the widest spray of light and the most attractive style of bulb itself, many people choose the candelabra bulb. This bulb is versatile and can be sued in a number of different settings and mounts. It can be hung from an overhead mount or, as is popular in many cases with outdoor low voltage LED lighting, it can be mounted into the ground and projected upwards to capture the underside of a set of stairs.
LED Bars
LED bar bulbs are, as the name suggests, long rods that produce lower amounts of light than fluorescent bulbs. They can be used to great effect in a cascading manner down the sides of a set of stairs or, if you prefer, to illuminate a pathway along the ground. Many people prefer LED bar bulb types over others as well, because they oftentimes provide the best longevity in comparison with other types of light bulbs.
LED Strips
LED strip style bulbs are mounts where you can attach a variety of different types of component bulbs into the same unit. This is a good plan if you're focusing on one primary area for your light to shine. If you're interested in setting up a single set of light bulbs, this is a great way to consolidate your wires and your electrical power. Additionally, these strips can be attached to one another and lined up into multiple strip lighting arrays as well. The strips are also waterproof, which makes them a preferable choice over many other types of lighting setups that you may be considering for the outside around your home.
Small Base Bulbs
Small base light bulbs are used typically for ornamental lighting outside. This includes lights that are hanging around a doorway or illuminating a sign on the wall or a plaque on the ground. These lights are small, provide a minimal amount of light, and help to create the perfect atmosphere or ambiance in a certain part of your yard.
For more information about LED lighting setups in your area, speak with a professional.
 forum activity
