Login Error
Close
Top-Performing Drill Bit Sharpeners
by DoItYourself Staff
A drill bit can be one of the most important tools that you need, and drill bit sharpeners are one of the most important parts that should go with that drill bit. If you are starting project and your drill bit is dull, it could lead to a delay in your project, or you may be forced to go and find a different drill bit or go out and purchase a drill bit. Making sure that you have your drill bit sharpened is of utmost importance.
Electric
There are many different drill bit sharpeners out there, and it can be difficult to choose which one would be the best for you. There are many different kinds of sharpeners out there, including electric sharpeners. Electric drill sharpeners can vary in size and functionality. These are oftentimes programmed to sharpen your drill bit to the correct sharpness, taking the guesswork out of sharpening for you. Electric sharpeners can vary in prices and can range anywhere from twenty dollars to well into the hundreds of dollars. Make sure that if you purchase a electric sharpener that you have a receipt of your purchase and warranty information on the sharpener in case you ever need it.
Simple Sharpeners
If electric drill bit sharpeners are not an option for you, there are more simple options for you. There are simple files that you can buy and manually sharpen the drill bit yourself. These files can typically used to sharpen many instruments, including the drill bits. These are usually fairly inexpensive and will last a long time.
Size and Storage
Drill bit sharpeners will vary in different sizes, and you will find one to fit your needs quite easily, depending on what type you need. If you have little storage space, a handheld model may be required. There are also models that you can mount on top of a table or work bench or one that you can simply carry around with you.
Battery Powered
If electric and hand held sharpeners are not right for you, you may want to consider a battery powered sharpener. A battery powered sharpener can be carried anywhere as long as the battery is charged. There is a broad variety of batteries that can be used, depending on the model. You can find some sharpeners with simple double or triple A batteries or sharpeners that need batteries like 9 volt rechargeable batteries. Remember to take great care of your batteries, and your battery powered drill bit sharpener will last longer.
Having a good drill bit sharpener will ensure that you will never have delays on your job nor will you have to go out and purchase another drill bit. A great tip to keep your sharpener working smoothly is to make sure that you clean it well and always store it properly. Make sure that no matter which kind of sharpener you purchase, you take care of it properly and ensure that it will have a long life.
 forum activity
