Login Error
Close
Travertine vs. Marble Floors
by DoItYourself Staff
Travertine is a natural stone flooring product that is popular with homeowners because it's durable and easy to lay. There are differences between travertine and natural marble, but which of these flooring products should be used in different rooms of your house?
Flooring Options
There are loads of different types of flooring which are suitable for use in homes and offices. The choice you make will mainly depend on the appearance and your personal preferences. You will also need to consider the amount of traffic your floor receives and whether or not you have kids.
Travertine
Travertine is a very similar product to marble in some respects. Both travertine and marble require regular maintenance to keep them in good condition.
Marble
Marble was once a very posh flooring material which was only ever found in mansions, however these days many normal houses are using marble as a flooring option. It's perfect if you have children or animals and works well in very hot or cool climates.
Marble is more than just a flooring material, it will actually add value to your home. Many different types and colors of marble are available. When installing marble floors it's important that it is done professionally. Marble is an expensive material and needs to be treated properly with regular cleaning and maintenance. Marble is a surprisingly a porous material, which means it can stain if not treated properly.
What Is Travertine?
Travertine has been used for many centuries. It has been used by the Romans to create the coliseum and many other surviving antiquities. Travertine can be found in natural or polished finishes depending on the look you are trying to achieve.
Installation
When you are installing either natural travertine or marble flooring, there are some very important things that you will have to bear in mind. First, both of these products are heavy. Make sure you can physically lift them before starting the installation project. You will also need to use a very strong adhesive to hold the tiles in place. Standard ceramic tile adhesive simply won't do.
Natural products are easier to match because the colors remain much more constant than man made floor coverings. This means that you don't have to worry about buying a specific batch or color number.
Sealing
Whether you choose marble or travertine, the most important thing that you need to do is seal it. All natural flooring products are porous and this makes them susceptible to stains and other damage. Choose a stain which is suitable for your flooring material and ensure that it is used as directed. This will give your flooring all the protection it needs and it should be able to last for many years to come.
If you are ever in doubt abut the flooring products that you should use, you can always ask for help and advice at your local home hardware store.
 forum activity
