Login Error
Close
Tray Ceiling Crown Molding Installation
by DoItYourself Staff
One of the decorative works used as an interior design jobs includes ceiling crown molding. It provides an attractive finish to the joint between the wall and the ceiling. It can be used to make repairs at the same place in case there are faults or gaps. Tray ceiling crown molding is available as thin or wide strips. The height of the wall determines the type of decorative substance to use. The ceiling mold installation are made from wood, plaster, medium-density fiberboard, stock strips or routed moldings.
Wood
Wood requires elaborate hand carvings, if there is need for decorative patterns on the surface. Coming up with such jobs is time consuming which makes wood an expensive crown ceiling molding substances. However, it makes one of the most attractive finishes because different woods can be used.
Plaster Molding
This type of finish is applied by casting or painting. Installing the finish is a laborious and time consuming job. It requires some level of expertise, which makes it equally expensive. Plaster moldings are suitable for use when repairing faults or gaps at joints found between the ceiling and walls.
New Lightweight Materials
Today there are light weight materials that make it easy to install tray ceiling mold in the home. They are equally affordable and provide a wide range of designs to choose from. Stock trips and routed moldings are available in varying designs. The fact that they are made from light weight substances makes it possible to select complex designs from a varying design profiles.
Medium-Density Fiberboard
This type of crown ceiling molding is made from fiber and it is available in a varying designs, sizes and styles. It is one of the best materials to use because it is affordable and easy to install. Wood fiber is pressurized to come up with the product. This makes it possible to sand, cut, paint and polish it. It has great consistency and provides a smooth surface and finishing.
Installing Tray Ceiling Molding
To get a great finish, consider the width of the crown finish to be installed in a particular room. For very tall walls and high ceilings, it is best to use wide strips with elaborate decorations or designs. This provides a good perspective and makes the finish look proportional to the entire room.
For low ceilings, narrow strips of crown molding works best. It is important to take care of the corners as well. This depends on the material being used. Make sure the wood is cut precisely according to the joint so it has seamless finish. It should be tight and perfect. When using plastic moldings, the corners have to be preformed depending on the type of joint present.
Choosing Designs
Select a design and material that best suite the size and the interior décor already present in the home. Crown ceiling moldings can be used to set the theme for decorations to be used. They can also be carefully integrated with other decorations that are already available.
 forum activity
