Login Error
Close
Trendy Kitchen Backsplash Ideas
by DoItYourself Staff
Look at the style of your home when getting kitchen backsplash ideas. There are several options and depending on how unique you want to be, almost any material can make a backsplash. The purpose of the backsplash is to protect the wall from the oil and elements of cooking, but it can also add a decorative and more elegant look to any kitchen.
Paint
The easiest and most cost effective way to designate the backsplash area is to paint it. This method will involve the least amount of effort and money. To really make a noticeable transformation, choose a different color than the rest of your walls. Since it is a smaller amount of space, a bold color will really make a big impact. Make sure you get a high semi-gloss paint. This area will need to be resistant to high amounts of food residue and being cleaned often. They also make special paint for kitchens. These specialty paints may be a good option, if available.
Tile
This is one of the most popular options for kitchens. Tiles come in all sorts of designs, styles and materials. They have mosaic, porcelain, glass and natural stone tiles. Although you should match the tile to the countertop, you can choose something that accents it and goes with something more bold.
To really make a "splash" make a design or pattern from the tile. Right above the oven is a great place to put the mosaic design or incorporate a pattern throughout the area. If you are not comfortable making the design, there are many pre-made mosaics you can buy. Make sure to seal the grout for easier cleaning and to prevent staining.
Stainless Steel
This is an increasingly popular design element. For a more modern feel, you could choose a stainless steel backsplash. This method would look great if you already have incorporated stainless steel appliances. It gives the kitchen a much more modern and sleek look. Pick a magnetic piece to add an extra function. This serves as the cleanest option. This material is easy to clean and long lasting.
Unique Techniques
Any non-porous material can me transformed into a backsplash. Keep in mind the functionality of the material. Corkboard can easily be applied to the wall. It comes in rolls with glue backing. Decorate the corkboard with decorative, recipes and artwork. You can hang kitchen utensils from it as well.
To make it easier to clean, consider applying a spray adhesive topcoat. This will make it waterproof and then can be wiped down when it is dirty. Wallpaper comes in so many designs and can "spice" up any kitchen with color and design. Glass or mirrors can also be used as backsplashes. While they are easy to clean, if you have a busy kitchen this may not be the best choice due to breaking and the cost of replacing.
 forum activity
