Login Error
Close
Troubleshooting a Battery Free Wireless Remote Light Switch
by DoItYourself Staff
what you'll need
  • Screwdriver
  • Pliers
While most light switches are operated through a standard electrical wiring system, a new generation of wireless remote light switch has become very popular in new and old buildings both. These light switch systems require no electrical wiring and are easy to attach. In fact, they don't require a switch box to be placed behind the switch itself. They are especially useful in locations that might have a variety of different tenants or users over the course of many months or years. A wireless remote light switch can be moved virtually anywhere within a certain radius of the light system itself, allowing for a great degree of flexibility as to the design of the switch locations. However, as with all appliances, wireless remote light switches can sometimes have technical malfunctions. Read on for some tips on troubleshooting these issues.
Step 1 - Check the Signal Range
Battery-free wireless remote light switches typically operate through the use of radio signals. These radio signals transmit information between the switch itself and the lighting system, and are the equivalent of the wiring setup in a wired electrical and standard lighting switch system. As with other radio-powered devices, however, wireless remote light switches have a certain range of functionality. If you move the switch outside of the proper range, it will lose its effectiveness.
If your battery-free wireless light switch doesn't seem to be working properly from the outset, it's possible that you have been trying to activate it from outside of the proper range. The first step toward troubleshooting this issue is to move the switch closer to the lighting system itself and try again.
Step 2 - Check for Radio Interference
Other radio powered devices may influence the transmission of the radio powered wireless remote light switch to the lighting system. If this happens, the signals may be interrupted by the signals of another wireless device. Some of the potential interrupting devices include phones, wireless printer and stereo system setups, and more. If moving the switch closer to the lighting system does not have any positive effect, try moving other radio powered devices outside of the room, or at least turn them off temporarily.
Step 3 - Check for a Defective Transmitter
If you have multiple wireless remote light switches, as is likely in a multi-light system, try switching to a different remote switch to see if that one works instead. If you have continuing issues with just one out of several light switches, it is probably that the single switch itself has a malfunction of some kind. However, if none of the switches work properly, it is more likely that part of your connection is set up incorrectly or that there may not be power flowing through it.
In either case, at this point it is probably easiest to consult with an expert or with a representative from the manufacturing company that provided you with the lighting system and the switches in the first place. They should be able to provide additional assistance with information that is specific to your system.
 forum activity
