Troubleshooting a Clothes Dryer: Drum Doesn't Tumble
When troubleshooting problems with your clothes dryer, you need to be able to diagnose a number of different problems. One situation that you’ll often encounter is where the drum won’t turn.There can be several reasons for this and a useful troubleshooting list can help to provide a number of effective solutions.
Does the Dryer Start?
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won’t, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you’ll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won’t connect with the switch. You can try to straighten the peg, but if it’s broken, you’ll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
Dryer Starts But Drum Won’t Turn
If the dryer will start but the drum refuses to turn, there are three possible causes; it will be due to problems with the belt, the motor or the capacitor.
The belt is the easiest problem to check. Try to turn the drum with your hand. With a working belt, the drum will be a little stiff, and you’ll need to put in some effort to turn it. If it turns very easily and loosely, the belt has probably broken.
To confirm this and troubleshoot the clothes dryer, unplug the appliance. Next, you need to remove the lid after which you should be able to see the belt around the drum. Lift it to see if there’s adequate tension (be aware that there are instances where a broken belt has stayed attached to the drum so it could come off in your hand).
Replacing the belt can be a tricky job since it’s not easy to access the area you need to work on. Often, the heating element for the dryer is behind it. You can still do the job yourself but you’ll need to take care and know what you’re doing. The simplest solution for this can be to hire a professional.
Motor Problems
If the dryer makes a humming noise but the drum won’t turn, it’s fairly easy to troubleshoot the tumble dryer as the problem will be in the motor. The motor itself might be jammed or there could also be a fault with the capacitor.
You can try checking by turning the dryer on, reaching in through the door to spin the drum by hand and closing the door again. If the dryer starts to work until it has to stop to reverse, you can be certain the problem is in the capacitor. You need to be aware that a capacitor can hold an electrical charge even after the dryer has been unplugged so you need to be very wary if you try to replace it yourself.
