Troubleshooting a Dishwasher that Won't Drain
If you find yourself troubleshooting a dishwasher that won't drain, you won't be the first person to face this challenge. Although there can be a number of reasons for dishwasher's failure to drain, it shouldn't present a major challenge for you to find and fix the problem. There are a limited number of reasons your dishwasher may not be draining. Follow the troubleshooting steps below to get your dishwasher draining again.
Step 1 – Check for Clogs
First, check the sump (bottom) area of your dishwasher. If you have more than 1 or 2 cups of water there, use a container and remove as much of the water as you can. Then, check to see if there is food debris, paper, or other scraps that might be clogging the drain. If, upon first checking, you find only a small amount of water, this is not necessarily a sign that your dishwasher is not draining. Typically, there is a small amount of water intentionally left there to keep the seal from drying out.
Step 2 – Check the Door Latch
An unlatched dishwasher door will keep your dishwasher from draining. If it is unlatched, latch it and check it again to see if it drains.
Step 3 - Check the Operating Components
If there is a component failure you should be able to spot it by checking the drain valve, pump, motor, solenoid assembly, drain valve, belt, drain line and air gap. If your dishwasher has a belt drive, check to see if the belt has broken or has slipped off the pulley. If you need help in identifying any of these components, check in your dishwasher owners manual or call the manufacturer.
Step 4 – Check your Garbage Disposal Drain Plug
The drain plug in your garbage disposal (a small plastic insert ) should be removed. A dishwasher draining through your garbage disposal, try running your disposal to be sure this drain is not plugged.
Step 5 – Check for Possible Blocking of the Drain Hose
Locate the drain hose between the pump and drain line and check for a possible blockage or kinking of the hose. You may have to remove the drain hose to make this check. The hose is held to the drain valve and disposal by clamps. Loosen these clamps, remove the hose, and inspect it for a blockage. If there is a blockage and you are unable to remove it, you may need to replace the hose.
Step 6 – Check the Motor
Test the motor to see if it is running properly. Turn on the dishwasher and listen for a hum. Be sure the dishwasher is plugged into an electrical receptacle and is getting power. If you hear a hum, this suggests the motor is receiving power but is not turning. In this case, you will need to replace the motor.
Step 7 – Check the Drain Valve
Normally, as this valve gets power during the drain cycle, it opens a solenoid and allows water to drain. But not all dish washers use this valve. If yours does, and if it is not working, you may need to replace it.
