Login Error
Close
Troubleshooting a Water Distiller that is Electric
by DoItYourself Staff
A water distiller that is electric is a machine used to distill water in your home. An electric water distiller is useful for those parts of the country with poor water quality or can help alleviate concerns that you may have over the quality of drinking water in your home.
An electric water distiller uses a filtration system similar to that of a manual water distiller. Water is fed from your tap through the home's plumbing and is separated to produce better drinking water quality. The mechanics behind an electric water distiller is pretty straight forward and simple. Troubleshooting problems with your electric water distiller requires little technical skill.
Common Occurring Problems
The problems that can occur with your electric water distiller includes:
  • cloudy or discolored water
  • failure to turn on and off properly
  • the motor component is too loud or noisy
Each of these problems can be addressed once they have been identified during your troubleshooting process.
Cloudy and Discolored Water
If the water from your electric water distiller is coming out cloudy or has a discolored look, the problem can be addressed by changing or putting a new water filter into the unit. The water filter does not have an infinite period of time that it can be used and should be replaced on a periodic and regular basis.  Maintaining a regular schedule for changing the filter in the electric water distiller should be based on the frequency of the electric water distiller uses. Changing the filter is a simple fix that should eliminate the problem of cloudy or discolored water. You may also look into changing brands of filters for your electric water distiller as a way to further address this problem in order to eliminate the problem altogether.
The Electric Water Distiller Does Not Shut Off Properly
When engaged in operation the electric water distiller should turn on and off with little effort once the switch has been engaged. A bad on or off switch may indicate that a short exists in the wiring to the switch that needs to be fixed. You can either look to purchasing a replacement switch for the electric water distiller, or if the unit is old, purchasing a new electric water distiller as a replacement.
Your Electric Water Distiller Is Running Loud
You will need to check the engine components to your electric water distiller if you are experiencing a problem with the unit running loud or noisily. This problem can be due to the age of the distiller, which can be easily addressed by replacing the component with the electric water distiller that is making noise. You should also look for evidence of rust (brown stains) that can also be the cause of wear and tear on the internal components of the electric water distiller. Evidence of rust means that you need to change the type of filter being used or contact your local water department to ask for additional treatment options.
 forum activity
