Login Error
Close
Troubleshooting an Electric Stove: No Burners Work
by DoItYourself Staff
Stoves get a lot of use every day and this is why it's important to find out how troubleshooting stove can help to correct any problems you might be suffering from. An electric stove is very common because this is such a clean and convenient way of cooking. If none of the burners on your electric stove work then you will need to find a way of solving the problem. Oven problems don't need to be the end of the world, they can actually be solved very easily. In order to solve any of these problems you will need to be methodical so that you can find the actual cause of the problem and figure out how to correct it. It is possible to do many of these troubleshooting tasks yourself, however, if you are not confident at working with electricity then you might be better off hiring a professional to do the job for you. A professional will be able to inspect the circuits and find the exact cause of the problems.
Checking Fuses and Circuit Breakers
One of the first things that you need to check is that the fuse and circuit breaker isn't tripped. This will cause the burners on your electric stove not to work due to lack of power. Your cooker should have a dedicated power supply, in which case you should check the circuit breaker in your homes electrical panel.
If this has tripped, then try to turn it back on. If the cooker circuit keeps on tripping then you will need to investigate further to find the actual cause of this.
Checking the Switch
Assuming your electric cooker was installed properly it will have an independent switch to control the power supply. Check that this is turned on. Then unscrew it from the wall and check that the switch is functioning correctly. If the switch is faulty then this could be the reason your electric circuit keeps on tripping.
Checking Wiring
Rats, mice and other rodents often bite through wires which could result in electrical problems. If none of your burners are working then this is a possibility. Check the wiring using a circuit tester. This will help you to identify whether any of the wiring needs to be replaced. If the wiring does need replacing then you may need to hire a professional.
Checking Cooker
If none of the burners work then this could also be a result of faults inside the stove itself. If any of the wires are damaged or the connections are shorting out then this will need to be corrected. Hire a professional to check the cooker if you don't think you can do this yourself.
If the cooker is very old then it might be beyond economical repair. This might make it a much better value to consider replacing the cooker with a new model rather than trying to repair it numerous times.
 forum activity
