Troubleshooting an Ice Maker: Ice Tastes Bad
When troubleshooting ice makers there are a number of steps that you can take to find the cause of the problem and put it right. One common problem is when the ice doesn't taste right. If the ice tastes bad then there can be a number of reasons for this.
When working out why the ice tastes bad there are several things that you will need to consider. The problem could also be caused by one or more of the factors which could make solving it slightly move complicated.
Washing the Ice Bin
The ice bin is the container which stores the ice, if this becomes dirty or moldy it can make the ice taste nasty. Simply taking the ice bin out of the freezer and then washing it will solve the problem. Read the instruction manual to find out where the ice bin is located.
Unscrew or unclip the ice bin and then wash it in warm soapy water. Dry the ice bin and then reassemble it. Place it back into the fridge and then find out whether it has resolved the problem.
Old Food
If there is any old food in your refrigerator then this should be removed. The ice could taste funny because of this food. Empty your refrigerator of any old food and wash all of the shelves so that the fridge is completely clean.
Once the old food has been removed and the fridge has been cleaned completely you should then test the ice maker to find out whether the problems still affect you.
Flushing the Supply Line
The supply line carries water to the ice maker. Sometimes the water can become stale which is why you might be able to cure the problem by flushing the water pipe out with fresh clean water.
Test the ice maker after flushing the supply line to ensure that the water is now clean that the ice doesn't taste bad.
Water Inlet Valve
If the water inlet valve is damaged then this could also be because of the water inlet valve. If the water inlet valve is damaged or broken. This can leave the water exposed to smells inside your fridge which can make the ice taste bad.
The water inlet valve will need replacing if it is damaged or broken. By replacing this water inlet valve you will be able to correct the problem and enjoy better tasting ice.
Replacing the Water Filter
There is a water filter inside of your fridges ice maker which is designed to remove particles and bad smells from the water. The water filter needs to be removed and replaced.
The water filter should be replaced with the same type and model suitable for your freezer. Use your freezers model to ensure that the correct filter is fitted.
Supply Line Filter
If your fridge doesn't already have a supply line filter then fitting one could greatly help to reduce problems with the ice tasting bad. These can be fitted to virtually any ice maker.
If you're looking to purchase an ice maker, check out our Ice Makers Buyer's Guide.
