Login Error
Close
Troubleshooting an Outdoor Faucet with No Water Running
by DoItYourself Staff
Finding that your outdoor faucet isn’t running water can be a real inconvenience. The chances are that you’ll only discover this problem when you actually need your outdoor water supply for watering your lawn or filling the pool. Although it can be incredibly frustrating to find yourself without an outdoor water supply, there are a number of things you can do to troubleshoot the problem.
Stopcock
Sometimes, it's the most obvious thing that we fail to check. If you live in a cold climate, check to see if the water supply to the faucet has been shut off for the winter. If you live in a building where the outdoor water supply is communal, it may be that the maintenance team did this to prevent the pipes from freezing during the cold weather.
The stopcock or shut-off valve is usually the main cutoff point for household water supply, and it can usually be found in the utility room or boiler room area of apartment buildings. Check to see if the stopcock is turned on. If it is closed, simply turn the stopcock back on to return the water supply.
Water Supply
It’s always worth checking to see that you actually have a water supply inside your home. If you don’t, it might be an external problem with the water supplier. Under these circumstances, calling your water company is a good idea.
If they are currently working on a problem that has a direct effect on the supply to your property, they’ll be able to tell how soon you can expect your supply to be switched back on. Although you still won’t have a water supply to the outside water faucet, you will have discovered that the problem lies elsewhere.
Frost-Proof Spigots
An outside faucet should have a frost-proof spigot. Once you’ve established that the stopcock is in the on position and an internal water supply is present, it's a good idea to check the spigot for blockages. Most modern faucets are fitted with a frost-proof spigot as they are resistant to freezing. However, they are still vulnerable to sediments and other blockages.
Most spigots can be undone quite easily using a spanner. It’s best to turn the water supply off when dismantling the spigot, even if no supply appears to be present. Once the spigot is disassembled, check for blockages and put it back into position. It’s surprising how even the smallest particles of limescale or grit can prohibit water flow. Vinegar is great for dissolving limescale, and because it's something most of us have in our kitchens, it’s very convenient as well!
Washers
A washer is a small, black rubber ring found inside the faucet. After several years of use, they are likely to perish and fall apart. This can leave rubber particles inside the workings of the faucet and prohibit the water flow. Replacement washers are inexpensive and easy to fit. This task can be carried out by removing the retaining nut on the faucet handle and simply adding a replacement. Be sure to remove any damaged pieces of old washer first.
 forum activity
