Troubleshooting Common GFCI Outlet Problems
A GFCI outlet, or a ground fault circuit interrupter outlet, is a kind of gadget that will protect you from being shocked or electrocuted. These special kinds of outlets are installed in parts of the house where shocks are most likely to happen, such as outdoors, swimming pools, kitchens and bathrooms. The GFCI outlet has a built in sensor that detects any current change. Any significant change will prompt the system to shut down to protect you from the impending shock. Because these outlets are very important in any home, troubleshooting them should be on the homeowner’s list of what-to-know.
GFCI Keeps Tripping Due to Wear and Tear
GFCI outlets are vulnerable to wear and tear too so expect your outlets to be less effective over time. One of the symptoms of an overused GFCI outlet is that it trips more than usual. This is because a worn out GFCI outlet is not able to adjust to the electric current variations as well as a new one. For this reason, when you use your outlet for hair dryers and heaters your GFCI outlet is prone to tripping. In order for you to solve this problem, simply get a new GFCI outlet.
GFCI Keeps Tripping Due to the Black Wire Touching the Ground Bare
If your GFCI is relatively new, the problem could be in the black and white wires. Turn off the circuit breaker for the GFCI outlet that is having problems. Then unscrew your GFCI outlet and pull out the outlet from the box. Take out the black and white wires from your GFCI outlet. Using your ohm meter, check if there is continuity between your GFCI outlet’s ground, and the white and black wires. If you get continuity from disconnecting the white and black wires then the problem could be that the white and black wires are touching with the bare ground. A black wire coming in contact with a bare ground usually results in a tripped outlet. This problem is often referred to as a leak in the circuit.
GFCI Keeps Tripping Due to a Defective Circuit
The GFCI outlets are often connected to each other in your house. This is why if a GFCI outlet has tripped those downstream the current will be affected likewise. When it comes to installing a GFCI outlet, you have to make sure that it is connected well to the entire circuit. You have to connect the panel wires to the line terminals. There are two terminals in your GFCI, the load and the line.
Since all of your GFCI outlets are interconnected, it is wise to have a system of wiring everything so that you can easily make circuit modifications. Check out all the GFCI outlets In your house and remove the defective ones. Remove the dead ones and then make pigtails for the hot wires and white wires of the GFCI outlets and connect all that into the line terminals. The black wires should be connected to the brass line terminals while the white ones to the silver line terminals. Doing so will allow your GFCI outlets to trip only when it’s really dead.
