Login Error
Close
Troubleshooting Common Problems with Your Refrigerator Outlet
by DoItYourself Staff
There are a number of problems that can cause a refrigerator outlet to stop working correctly. Try the troubleshooting tips below to diagnose your problem and take steps to fix it.
1. The Fuse Board
First, you must check the fuse board or circuit breaker. A blown fuse or tripped circuit breaker is one of the most common reasons for trouble with any electrical outlet. Fuses are designed to protect you by blowing if there is anything wrong with the circuit. Spend time checking the fuse board.
2. The Outlet
Check the condition of the outlet to ensure that it's still safe to use. Damaged outlets can not be repaired, but they are so cheap that it's simply a matter of replacing them.
3. The Wiring
Sometimes the wiring can start to cause trouble in older properties. This is because over time, it will start to degrade and suffer from problems. Check the condition of the wiring by using a circuit checker.
4. The Connections
Spend time checking all of the connections to ensure that the fridge receptacle is wired up correctly and that nothing is shorted out. This will ensure that the fridge outlet will work properly without any problems. The terminals should be tight and the wires should be held securely in place. If any of the wires are loose, tighten or replace them.
5. Broken Circuit Breaker
There is also the possibility that the circuit breaker is broken or damaged. Circuit breakers are very reliable however they do have a certain life span. After which time they will need to be replaced. It's important to check the circuit breakers regularly to ensure that they are protecting your home's electrical systems the best they can.
6. Overloaded Circuit
There is also the possibility that a circuit is overloaded. If this is the case, you may have to re-wire your home. Ensure that you check the limits of your circuits to ensure that they are not being exceeded.
7. Faulty Wiring
If the problem is caused by faulty wiring, then you will need to hire an electrician to help repair the problem. Repairing electrical systems can be very difficult and that's why you must make sure that it's done properly.
 forum activity
