Login Error
Close
Troubleshooting Drain Problems
by DoItYourself Staff
Solving drain problems can vary from something as easy as mounting extensions along the rain gutter spouts to lengthen the drainage away from your home to intricate construction that calls for some specialized skills. Hence, the idea of excellent drainage is generally based on guiding water to wherever you like it better to go by in great consideration to your benefit.
Preparation
To prepare, gather your tools and materials. You will need:
  • Pick
  • Shovel
  • Drainage netting
  • Rocks
You also need to determine the location of the gas and water pipes. Ensure that you will be digging away from any of the two pipes. It is very hazardous to dig out without even tracing if there are pipes underneath the soil.
Saturation Concerns
When you do not have any main drainage issues but do not want your yard to pool with water, consider making a filled or lined drainage. This provides a set for the water to gather so it can gradually soak into the soil.
Know What You Want
Always predetermine your objective. If a creek or ditch underneath your property runs over following a heavy rain, you will deal with drainage at just one point or develop drainage further than your property. To provide water drainage with the most possibilities earlier than it leaves your property, the traditional troubleshooting solution still works.
Start Troubleshooting
The base of your drain, preferably at the lowest position on your property, settles on where the drain should go through. The spot where water rises during severe rains should conclude where the other edge of the ditch starts. Usually, the ditch’s lower end must be positioned at lower level than the higher side. A drain low at the centre could turn into a location for mosquitoes and insects to cultivate.
The next step is to fill the drain with rocks or gravel. Normally, you can cover the rocks with certain sort of screen or cloth, better known as drainage netting, to setback root growth in the rocks. Ultimately, root growth within the rocks will decelerate down the drainage.
Thinking Forward
If, after some years, the drainage pathway you excavated no longer works adequately, you can hollow out another drain nearby the other one. Nevertheless, because of land erosion, the subsequent drain may need a little different trail.
Hence, if you decide to put pipes in your drains, instead of the typical rocks, always replace the pipes after sometime to ensure its satisfying function. If you put in thin walled pipes in order to save some amount in the short run, after several months the plumbers rooter can rip them up. That would suggest forgetting that then dig another comparable drain for another pipe, which can cost you even more. You simply have the choice on what materials to use that can save you money. But always consider its durability and efficiency.
Finally, you can lay sod over it or even add decorative rocks along with some adorable potted plants of your preference.
 forum activity
