Login Error
Close
Troubleshooting DVD Duplicators
by DoItYourself Staff
DVD duplicators have become useful in the workplace where they are used to make copies of DVDs that have data information, videos, or documents on them. These are widely used in the office to prepare several copies of reports for record purposes. They are used in school settings to pass along projects to present in class. You even use DVD duplicators at home to make copies of home videos to circulate to loved ones. As with most electronic equipment, DVD duplicators may experience some problems and not operate properly. Below are some troubleshooting tips to help you fix your DVD duplicator.
Inspect the DVD
Some DVDs are sensitive to scratches or stains. These greatly affect the way that the DVD duplicator receives them. Carefully examine the DVD that you wish to duplicate and keep an eye out for signs of scratches or any form of damage. These will usually be on the shiny side of the DVD, otherwise known as the underside. You can purchase a scratch removal kit for DVDs which you can purchase at your local computer store. If there are minor dirt marks, you can use a cloth to wipe those away. Fingerprints must also be removed from the DVD’s underside.
Check the Connection
Examine the connection of your DVD duplicator. It should be connected to a power outlet or electricity source in your home. Also make sure that it is switched on if it has a on/off function. There are some DVD duplicators that can be connected to your computer system or laptop, and these make use of a USB connection. Check if the connector cable to the computer is connected. Check as well if the software for the DVD duplicator is installed into your computer.
Copy-protected Disks
Copy-protected disks cannot be duplicated. Examples of these are DVDs of movies or computer software. Most of these DVDs are purchased at authorized stores such as computer stores or video stores, and they come with a stamp or seal of approval indicating that they are original versions of movies or computer software. Attempting to rip the content of these disks and duplicate them is an act of piracy and illegal.
Check Size of File and DVD Type
DVDs can only hold a limited amount of data. Check the size of the file, movie, or document you would like to duplicate and make sure that these can fit into one DVD disk. Some DVD duplicators also require a specific type of DVD disk in order to duplicate the information or data given. There are recordable media files that can only be duplicated onto specialized DVDs for that specific type of file. There are different kinds of DVD formats, examples of which are DVD-Rs, DVD-RWs, and DVD+Rs. Make sure you review the manufacturer’s manual to see if the duplicator you purchased requires a specific type of DVD disk.
 forum activity
