Login Error
Close
Troubleshooting Guitar Preamp Problems
by DoItYourself Staff
A guitar preamp is designed to boost and enhance signals coming from a guitar before it reaches the amplifier. When on stage, no one wants to encounter technical problems with instruments or any other electronic gadget. Here are some troubleshooting tips you can use to solve guitar preamp problems before going on stage.
No Output
Check the power indicator and see if it is on or not. If the power indicator is not flashing or lit, check the switch and the electrical plug. Plug the device to an electrical outlet and turn the switch on. Inspect the electrical cable as well to see if it is physically damaged. Replace the cable as soon as possible. If the electrical outlet and electrical cable are in good condition, check for a blown fuse. Use a service manual to locate the exact location of the fuse. Open the back cover of the device and see if the fuse has dark residue in it. Replace the fuse.
If the power indicator is flashing, check the volume control and crank it up. If adjusting the volume does not work, check the output and input connectors. Ensure that these connectors are plugged fully into their respective jacks. If everything else is fine, check the output speakers or amplifiers. Turn them on and adjust the volume to the correct settings. Check if the speakers are connected to power outlets as well.
When both the preamp and the speakers are set up correctly, check if the guitar is turned up or not. If an effect pedal is connected between the guitar and the preamp, check the connections. The connecting cables may also be the culprit. Test every cable connection on the configuration to isolate the problem. Replace any defective cables.
Device does not Switch Channels
Inspect the foot switch and see if it is overriding the front panel selector or not. It should be configured to enable the foot switch to switch channels. Since the steps in configuration differ from one model to the other, refer to the owner’s manual for further instructions. Switching from one channel to the other can also be done manually. Manual switching is also called internal switching. If this feature is defective, refer to the service manual or have it serviced by the manufacturer. Just make sure that the warranty is not yet expired or void.
Important Notes Before Servicing the Internal Parts of the Guitar Preamp
If you suspect that the problem with the preamp is caused by damage in its internal parts, locate the warranty seal at the back of the device. See if it is still under warranty. Do not attempt to open the back panel or break the seal to prevent voiding it. Have the device serviced by professional technician from the manufacturer for free.
If the warranty is already void or expired, you can attempt to open the casing and inspect internal parts. Replace damaged parts with new ones. Refer to the service manual for the product number when purchasing replacements. Always exercise caution when dealing with electrical parts.
 forum activity
