Login Error
Close
Troubleshooting Halogen Headlight Problems
by DoItYourself Staff
Making use of a halogen headlight can prove beneficial for a range of different purposes, whether on the car or in the house. However, their usefulness will be instantly negated when they fail to work properly. An awareness of the types of problems that the light can suffer will make it easier to effect a repair.
Light Fails to Work
In the event that the halogen headlight fails to come on at all, you will find that there are a number of potential causes. One of the main reasons for the light not working is a burnt out bulb, which can be rectified by replacing the bulb with a suitable replacement. Similarly, if the connection point of the light has a defect, it will not allow the bulb to attach properly. When this is the case, the light fixture will need to repaired by replacing the defective components.
The wiring that connects the switch to the light must be considered as they can be at fault if the light does not come on when the switch is operated. Check the wires for fraying and burning, which can prevent the flow of power to make the light work. Remove any wires that have suffered a defect and replace them with exact replicas.
Flickering Light
If the halogen headlight only intermittently gives off any light, you may find that this is due to a poor connection. To check whether this is the problem, remove the cover to give you access to withdraw the bulb from the recess. You may find that debris has worked its way into the threads, which can prevent a proper connection being made. When this is the case, use a soft clean cloth to wipe around the threads before returning it to place. Where the bulb has been affected by rust, it is best to replace it entirely. The problem of the light flickering may also result if the bulb has not been fitted properly. Remove the bulb and replace it, making sure that it is properly aligned and inserted.
Insufficient Brightness
Where the halogen headlight is not bright enough for the purpose for which you are using it, you may find that this is due to an incorrect bulb being fitted. Check the wattage of the headlight to ensure that you get the correct bulb to allow it to work to its optimum level. Although there are a range of colors that bulbs are available in, you will find that many of them are illegal for use on a car to drive on the road. Make sure that you only use yellow bulbs for your headlights.
Varying Degrees of Brightness
Where the level of light does not remain constant while the halogen headlight is in use, you may find that this is due to a faulty transformer. In the event that it becomes overheated, you will find that it affects the quality of the light produced. This will require repair of the transformer to take place to ensure the lights are properly served.
 forum activity
