Troubleshooting Hot Tub Control Panel Problems
A hot tub control panel acts as a timer, keeps the temperature constant, turns off the spa if you forget to and helps troubleshoot problems with your spa. So it is important to keep the control panel in good working order.
Dead Control Panel
If part of the control panel is dead or the whole panel is frozen, you will want to see if the problem is the circuit board or the control panel. Examine the panel to see if any moisture is inside the display. See if the panel or any buttons are cracked or if it could have possibly gotten wet. If only part of the control panel is not working, check for any blinking lights or error messages. The first step is to simply reset the breaker. If there is still a problem, turn off the breaker again, disconnect the control panel and examine the circuit board. Now turn the power back on and see if the hot tub starts to filter or heat up. The only sure way to test the control panel is to get one you know is working and connect it to the circuit board.
Circuit Board
If you have tested the control panel and it does not work with one you know is good, you will probably need to replace the circuit board. Some symptoms of a circuit board problem are a blank or partially blank display, slowness in displaying messages, or LED lights that are not working properly. If you test the board and see it has low voltage, that is another sign you may need to replace the circuit board.
Displaying Dashes
If the control panel is not displaying an error message but only dashes, you need to reset it. Turn off the power for about an hour and then restore the power to the unit. This should reset the control panel.
Strange Messages
If the display is showing strange messages or blinking several lights at once, there may be a software problem or a problem with the circuit board. Locate the circuit board connect and see if any corrosion needs to be cleaned. If there is any condensation, dry it out.
Blinking Red Light
A blinking red light on the control panel may indicate it needs to be reset. For most models you will turn off the power to the spa for a minute or two and then turn it back on. Turn on the lower amp breaker first if you have a hot tub powered by 240 volts. If it is 120 volts of household power, simply unplug it and then plug it back in after a couple of minutes.
Blinking Red and Green Lights
If both red and green lights are blinking, this could indicate low water flow. Resetting the spa by turning off the power, waiting and turning it back on is likely to resolve the issue.
If these troubleshooting tips don’t solve your problem, consult the owner’s manual for your controller or contact the manufacturer for technical help.
