Troubleshooting Sink Soap Dispenser Problems Troubleshooting Sink Soap Dispenser Problems
Installing a sink soap dispenser can be a convenient and hygienic way to provide hand cleaning facilities. There are several faults that can reduce the effectiveness of it, which will make it necessary to be able to repair it. In order to ensure that soap will always be available, it is useful to know what problems can arise.
Solidified Soap
There will be occasions when liquid soap blocks the pump of the sink soap dispenser by getting into the wrong place and solidifying. When this occurs, the trigger and pump section of the dispenser will need to be removed by unscrewing it. Leave the entire component to soak in hot water for approximately fifteen minutes, following by pumping water through it in the same way that you would with soap. When it is clear, reattach it to the body of the dispenser.
Trigger Fails to Lower
In the event that the trigger of the pump is pressed but it doesn’t move, you will find that there can be several causes. Some types of dispenser have the ability to be locked by twisting it so start by checking whether this has occurred. Alternatively, a defect may have developed with the spring that makes up part of the mechanism. If you are able to access the spring, check whether it is properly aligned and put it back in place if it has become dislodged. Where this is not possible, the entire pump will need to be replaced.
Does Not Discharge Soap
When the sink soap dispenser is full but does not release any soap when the trigger of the pump is pressed, the problem may lie with the tube that gathers the soap. Unscrew the pump so that it can be properly examined and make sure that the tube is properly attached to the top. If the tube is not properly fitted, it will be prevented from pulling up the soap.
Another possible cause is damage to the tube itself, which may take the form of a hole or a split. When this is the case, either the tube or the entire pump will need to be replaced.
Trigger Remains Depressed
If the trigger of the sink soap dispenser does not come back up again after it has been pressed, the problem will lie with the spring in the mechanism. The spring is likely to have lost its tension or has been forced into a position that it should not be in. Unscrew the pump to determine whether you can gain access to the spring. If this is not the case, the pump will need to be replaced.
Pump Moves
In the event that the pump of the sink soap dispenser moves while it is in use, it is likely to be caused by incorrect installation. The pump section must be straight and properly screwed or pushed into place. If the dispenser is the type of makes use of a bottle of liquid soap, this needs to be fitted into the body of the casing properly.
Troubleshooting your sink soap dispenser problems is made easy with the help of this guide. Now you can wash your hands of these problems.
