Two Advantages to Recycle Waste Water From the Humidifier to Water the Lawn
One way to help the environment is to recycle waste water. You can do this by using your waste water from your humidifier to water the lawn.
Below are the two main advantages of using waste water to water outside.
1. Doesn't Need to Be Treated
Many homeowners may think that their waste water, well, is just that: waste water. In fact, the truth is that you can use it to water your lawn without even having to treat it first.
Waste water does contain particles, and some dirty debris, but it is very safe to say that your lawn can handle it. Rule of thumb is to use about a half gallon of waste water to every one square foot of your lawn.
Recycyling waste water for your lawn is a simple process. Take the treatment step and process out of it, and you have yet an even simpler way to do it.
2. Time and Money
Recycling your waste water saves you both time and money. It saves you time by actually not needing to do anything but empty a container. Your humidifier is full of waste water, so there is no need to find another container to fill up.
Running your sprinklers for hours making sure to hit each part of the lawn can become a bit expensive, not to mention water wasting.
Next time, before you dump out your humidifier water, step back and see where you could use it to benefit you in the best way.
