Login Error
Close
Two Handle Tub and Shower Faucet Repair Tips
by DoItYourself Staff
When it comes to DIY projects, repairing your two handle tub shower faucet is probably one of the easier ones. It is also one of the most money saving ones as well, saving yourself anywhere between $100 and $200 dollars.
Step 1 - Turn the Water Off
Before you start repairing any type of faucet, you need to make sure the water flowing to that faucet is turned off.
Step 2 - Remove the Screw Cap
Remove the cap by unscrewing it. Proceed to take the handle screw out, as this will loosen the handle so it can be taken off.
Step 3 - Take off Retaining Nut
Using a pliers, you will want to remove the retaining nut and then pull the cartridge out.
Step 4 - Out With the Old, In With the New
Remove the old o-ring by rolling it off of the stem. Before replacing the new o-ring, roll it in petroleum jelly to protect it, and make it easier to slide on and off. Then simply roll your new o-ring into place.
Step 5 - Back Together Again
Your final step will be re-assembling the faucet, and then testing for any leaks.
There you have it. A fast, easy, DIY project that just saved you a good amount of money! Good Job!
 forum activity
