Login Error
Close
Two-Handle Tub and Shower Faucet: Plumbing Explained
by DoItYourself Staff
A two-handle tub and shower faucet controls the amount of water that goes into your shower and into your bath tub through basic plumping. The faucet can also be used to control the temperature at which the water flows into the shower and the bath. Apart from deciding what type of faucet you would want from the many sizes and designs available, understanding how they work can help you make a decision too. The following article will help you to understand how the plumbing in a two-handle tub and shower faucet works.
What the Valves Do
All the water flowing into your home flows under a high pressure. To prevent it from running through your taps at all times, faucets are used. There are valves that can be used to control the flow of water from the main water supply too. The two-handle tub and shower faucet however has valves that can be used to control whether the water runs into the shower head and the bath tub or not. The two-handle plumping ensures that you can either have hot water from your water heater or cold water from your water tank running into a shower head or the tub. There are separate faucet valves for shower heads and baths.
The Faucet Handles
Most bathrooms have a single faucet handle which can be turned on for running water in the shower head or the bath. In a two-handle tub and shower faucet, you can have water running into your shower head and your bath tub at the same time. The handles and lever in this assembly not only control running water but you can also control whether you want hot or cold water to be running. The lever is commonly known as a diverter that on shifting in different directions can either force water into the shower head or the bath. Having 2 levers can help you control water flow in both the shower head and the tub by turning both the levers on.
Hot and Cold Water
There is a hot and cold water faucet in a two-handle tub and shower faucet. On turning on, the faucet can allow both hot and cold water to run into the shower head and the bath. For using either hot or cold water, the faucet knob can be turned either to the left or the right for controlling water temperature. On moving the knob to the right usually, hot water flow increases and cold water flow decreases, resulting in a hotter shower or bath. Turning it the other way (the left) will give you the opposite result.
What is different in the two-handle tub and shower faucet is that you can control the water flow and temperature for the shower head and the bath tub at the same time. This is achieved by having double the handles, levers and temperature faucets than a normal tub and shower faucet.
 forum activity
