Login Error
Close
Types of Outdoor Privacy Screens You can Make at Home
by DoItYourself Staff
Outdoor privacy screens provide home owners with a means of securing their personal space outside. They can be made in a variety of sizes, styles and colors to match any landscaping décor. These landscaping additions are particularly common in urban areas where homes are situated more closely together. Screens can also provide areas of shade depending on their installation location. Deciding on the best type of outdoor privacy screen for your situation can be challenging but by taking the time to consider all of the aspect the task can become less daunting.
Styles
There are three basic types of outdoor privacy screens. The first type is made from materials such as metal, wood and vinyl. The second type is made from living materials such as trees, shrubs and plants. The final type is a combination of both living and non-living materials. Non-living screens can be free standing or attached. They can be purchased as a pre-fabricated unit or created from plans. Living screens are designed to incorporate shrubs and trees and require the precise placement of these items. The greenery can be planted in pots which allow for mobility or planted in the ground as more stable grouping. Combination screens are composed of plant life and composite material. A wooden trellis could be installed through which you might have vines growing.
Planning
Outdoor privacy screens can set a tone in your landscaping décor or complement the design aspects that are already in place in your yard. In either case, you will need to take some time to plan out the design for your screen. The features to consider include: the height, the length, the supports, the style, lighting components and the means of creating the screens.
Time Requirements
Building an outdoor privacy screen can be a simple and easy job for a home owner. The amount of time spent on the project varies depending on the size and style of the screen you are building. Free-standing lattice screens can be created and erected in a short amount of time. Fences and larger lattice screens will require more time. The precise location will need to be determined and the area will need to be made accessible. The supports for these screens will have to be built and installed along with the screens themselves.
Gathering Materials
Plan on spending some time choosing and purchasing the materials you want to use for your outdoor privacy screen. The choices are endless and you will need to take the time to determine what will work best for your home. Some materials can be readily purchased while others may require special orders. Some plants will need a time period to be trained properly in order to fit into the layout. For living and combination screens you will also need to take into consideration the necessary food and vitamins for the plant life in order to maintain their healthy appearance.
 forum activity
