Types of Paint to Use for Fiberglass Doors
Fiberglass doors are often preferred for their mold and rust resistance. Unlike wood, they will not deteriorate or swell. They can also be less expensive than wood and metal doors. While fiberglass doors can be painted, there is a bit more effort involved to ensure the finish lasts.
When it comes to painting fiberglass doors, it requires some planning. As there are different types of fiberglass, there are different types of paint. Knowing what paint to use for a proper bond is especially important. Types of fiberglass include epoxy resin and polyester-based resin. They require an epoxy-based paint and a polyester-based paint, respectively.
Primers
Fiberglass, as with other materials, is primed first and then painted. Once you have determined the type of fiberglass on your door, you will need a primer that is compatible. Urethane, epoxy, and latex primers will work with most types of fiberglass and fiberglass paints. Always check the primer's label for recommended topcoat paints. Etching primers are not recommended because the etching chemistry isn't compatible with fiberglass.
Types of Paint
Fiberglass paints can be found with varying degrees of shine or gloss. There are high gloss, regular gloss, and flat finishes. As water and sunlight can weaken fiberglass over time, it is important to consider a paint that will endure these elements. Any paint you choose should be classed as an exterior paint. Exterior paints are made to resist weathering. When choosing a fiberglass paint, do not use oil based or melamine. Acrylics (100%), polyurethanes, polyesters, and epoxy paints are best. Many manufacturers and painters will recommend that you do not mix primers and paints among various companies. For best results, they say to stick with one company for both applications. As mentioned earlier, if the fiberglass is an epoxy resin, use an epoxy-based paint. Use a polyester-based paint for polyester-resin fiberglass.
Selecting the right primer and paint for your fiberglass door will provide the necessary bond. This will prevent peeling, bubbling and
flaking. It will also ensure your door's finish lasts a long time and that the fiberglass underneath is well protected.
