Types of Roofing Materials that Require the Least Maintenance
Today there are many types of roofing materials to choose from. Each types has its pros and their cons and subsequent price tags and ways to install them. At the end of the day you want to know how to clean them. You want a roofing material that will do its job properly while being easy to take care of if not be completely maintenance free. The article below will share with you several types of roofing materials that fit this bill perfectly.
Green Roofing Membrane
Out of all of the other types of roofing materials you will be told about this is the most environmentally friendly. It takes some work to get it installed and flourishing but it is easy to take care, last for over 20 years and is virtually hands-off. The membrane goes over the wood roof and it allows you to lay planting soil on your roof so you can plant shrubs, bushes and other plants. The idea behind this type of roofing material is that it will absorb the sun, soak up water and keep the roof naturally cool. This are found more in urban areas as well as on flat roofs but the maintenance after the installation can easily be taken care of with a simple irrigation system.
Metal
Not many people consider types of roofing materials made from metal as a residential choice and yet it is growing in popularity due in part to its low maintenance and upkeep. In addition to being easily maintained metal roofs save a lot of money on heating costs as they absorb the sun’s rays differently than other types of roofing materials. They are also relatively inexpensive and easy to install. As long as you apply a new layer of weatherproof paint every ten years or so the roof will last over 100 years. The wood in the home will most likely rot and crumble before the roof does.
Asphalt Shingles
Asphalt shingles are the most commonly found roofing material due to their low price tag. They also do not require much maintenance as long as you live in an area where wind is not an overwhelming issue. You just need to remember that drainage is important and that removing heavy snow in a timely manner will allow the shingles to last for over 20 years.
Clay and Slate
Of all of the types of roofing materials you can purchase clay and slate are by far the most expensive. They will cost roughly $100 per square foot and upwards of $450 a square foot to install. The upside to this cost is two-fold; the first being that these two types of roofing materials will last well over 100 years if properly cared for and the second being that they actually require maintenance to keep them in perfect condition. A washing now and then as well as removing debris and snow in a timely manner will prevent them from dislodging or cracking.
