Login Error
Close
Typical Split-Level House Layouts
by DoItYourself Staff
The layout of a split level house may differ from model to model, but there is a typical pattern to them. A split level house differs from a basic two- or three-story house in that a split level home is usually built to conform to the surrounding geography. Split level homes are often built into hills with a portion of their frame underground. Besides that, there are a number of layout features that all split level houses share.
Typical Layouts of Split Level Homes: Location
As mentioned, split level homes are commonly seen built into hills. Their design is advantageous with this type of geography, but they are not always built in such a location. Split level homes are found on flat ground as well.
Garage
One of the defining features of a split level home is the position of its garage. Garages are not separate structures in split level homes; rather, they are a part of the design of the house. The bottom floor of a split level home is even with the garage. Thus, the door from the garage leads into the downstairs area and is directly below the main floor of the house.
Basement
A split level home does not have a basement, per se. Whereas the lowest level of a home is considered a basement in other homes, in a split level home the lowest level is even with the garage, usually with a door between the two. The lower level of a split level home often contains a laundry room, den and perhaps another bedroom and bathroom in addition to the garage. It is not a typical basement because the front end of the home is often above ground, while the sides and back may be partially buried.
Upper Level
The upper level of a split level home usually houses the kitchen, two to three bedrooms and one or more bathrooms. Upstairs you will also find the main living room and the dining room. Depending on the landscaping and geography, the rear of the home may look like a one-story house from the backyard. This is the case if the house is built into a hill.
Staggered Levels
Another common split level design is the use of staggered levels. The lowest level will evenly connect the garage with the den, laundry room and additional rooms. The main level will usually contain the kitchen, living and dining rooms. Split level homes that stagger the levels may have a third level that has several bedrooms and two or more bathrooms.
Landscaping
Split level homes built into hills will have landscaping that differs from homes built on flat locations. Typically, the backyard is at a higher elevation than the front. Whereas from the front the home will obviously consist of two stories, from the rear it may only look to have one story. As the ground slopes down towards the street, the levels open up and reveal themselves.
These are typical features of split level homes. Many homes of this nature have unique features that make them far from ordinary, although split level homes almost always incorporate some version of these designs.
 forum activity
