Ultraviolet Water Purification System Maintenance
Ultraviolet water purification systems have become one of the leading methods of water purification as the corresponding technology has advanced in recent years. These systems rely on small amounts of radiation to kill off any germs and harmful bacteria that may exist in a water supply, and are increasingly effective. One of the best features of these purification systems is the ease with which you can clean and maintain them.
Maintenance
The single most important aspect of ultraviolet water purification system maintenance is the changing of the UV light bulb. Most systems will provide you with instructions as to how to change the bulb. Some even feature the ability to change the bulb without disrupting the flow of water through the system.
Changing the Bulb
It is necessary to turn off the system and allow the system time to air out before you attempt to change the bulb. This protects you from potentially harmful radiation and from a bulb that may be very hot. If your bulb burns out, replace it before you turn the machine back on. If you wish to replace the bulb preemptively, before it completely burns out, follow the instructions on your purification system for the estimated lifetime of a bulb. This will help you to replace the bulb only when it is about to lose its functionality.
