Login Error
Close
Under Cabinet Kitchen Lighting Ideas
by DoItYourself Staff
Under cabinet kitchen lighting is a unique way of installing different lights in your kitchen space. These lights will help to not only illuminate the area underneath the cabinets in your kitchen, thereby providing you with task lilght so that you can see what you're doing as you work to set up any equipment that needs to be placed under there or complete any other projects, but also to have a unique way of lighting the remaining part of the room as well. Under cabinet kitchen lighting is distinctive and, in the right kitchen and completed in the right way, can change the look and feel of a room considerably and for the better. For more ideas of how to best install under cabinet kitchen lighting in your home, read on.
Modular Under Cabinet Lights
The most popular way of installing under cabinet lights in your kitchen is to install a single light that is set up as a sole module. This module can be attached either to the top of the interior portion of the cabinet or to one of the doors or sides of the cabinet. The wiring needs to then be run out of the cabinet and to a nearby power outlet, or to be connected inside of the wall to a close by wiring setup. These cabinet lights typically turn off and on by means of a single switch that is attached to the module itself. They are quite popular and will provide a small amount of light for anyone who has a difficult time seeing into their cabinet while it's dark.
Fluorescent Lights
Fluorescent under cabinet lights are another popular option for a way of lighting up the interior portion of your cabinet. These lights are generally brighter and more powerful than modular lights can be. They can also operate in a smaller space and require less in terms of a modular attachment to affix them to either the wall or the ceiling portion of the cabinet. However, many people find that they are unnecessarily bright for their use, so it may be best for you to avoid using fluorescent lights unless you know exactly how bright they'll be and you're sure that your cabinet space will need that much light in order for you to see everything that you're doing properly.
LED Lights
LED lights are the smallest and most compact of all of the options listed here. They provide a good quality light and are easy to install. Additionally, they are very environmentally friendly and use a small amount of energy. However, they do tend to be more expensive than some of the other lighting options that you'll find for under cabinet kitchen lights. This turns many people off from using them for their kitchen cabinet redesign project.
For more information about any of these options and other choices that you have for how to set up your under cabinet kitchen lighting, speak with a professional or an electrician in your area.
 forum activity
