Understanding Electrical Outlet Wire Colors
Understanding your home’s electrical outlet wire colors is just as important in knowing how the basic circuit types work. Basic knowledge on wire colors will come in handy during minor electrical emergencies such as changing an overhead light fixture, replacing a wall light or installing new bulbs, lamps and switches. Wires are color-coded to avoid wiring errors that may lead to accidents and electrical inconvenience of the household, the whole block or even in some cases the town.
Black Wires
Black-colored wires are specifically used for hot wires and voltage transmissions. Most of these wires are utilized as switch legs and may feed an outlet as well. You should not use these wires for a ground or neutral connection.
Red Wires
Red wires are second to black wires when used as hot wires and switch legs for 220-volt installations. Aside from using it for neutral connections, red wires can be used in 3-way switch configurations.
Yellow and Blue Wires
These wires usually come in pairs and pulled in conduits. They are used as hot wires and control electrical items like lights, switched outlets and fans. Blue wires are generally used in 3-way and 4-way switch applications by travelers. On the other hand, yellow wires are used as switch legs.
Copper and Green Wires
Copper-colored and green wires are used for grounding purposes only. They are specifically made for grounding electrical items and should be attached to appliance connections and junction boxes.
White Wires
Generally, wires in white color do not follow certain rules as compared to other colors. It can be sometimes used as a hot wire in a 2-conductor cable or can be sometimes used for outlet connection. It can either also run a 3-way switch application or as a switch leg for lighting. To avoid confusion on determining your white wire’s function, mark the wire’s end with red or black electrical tape.
Some countries have their own standard color codes too. For jurisdictions without standard rules for wire colors, local custom and common practices of electrical inspectors are usually followed.
United States
For both AC and DC connections, the United States National Electrical Code states that white or gray wires should be used as grounded neutral conductors. Copper, green and yellow wires should be used for protective ground. It is also common practice among local inspectors to use black for the first hot wire and use red for the second live or active wire.
Canada
The Canadian Electrical Code mandates green, yellow or green wires with yellow stripes to be used for protective ground. White wire is considered neutral. Black wires for single live wires, red for second active wires and blue for 3-phase active lines.
Europe
Europe’s International Electrotechnical Commission Code states that green-yellow wires are protective ground wires. Brown or black wires should be used for hot and live wires. For neutral ground, blue wire should be used.
General Rule
A good rule of thumb is to always connect wires of the same color. Before doing anything with the wires, always power down your main switch and use insulated tools as part of your precautionary measures.
