Uniform Fire Code Basics Explained
Uniform fire codes can make your home much safer and protect you from the natural danger of fire which has long been one of man's biggest fears. It’s very important that you find out about these uniform fire codes whenever you are planning to do any work on your house.
The uniform fire code is also known as the national fire code as this is the set of codes which most of America adopts. However, every state is different and it’s worth looking at the regulations specific to your state.
Emergency Exits
The latest version of the universal fire code is calling for an increased number of emergency exits on all buildings over 420 feet in height. This is a result of the attacks on the World Trade Center. An extra emergency exit is required for such buildings which means buildings over 320 feet must have 3 emergency exits.
Using Lifts in Emergencies
Most people know not to use elevators during a fire, however in some buildings you can. The uniform fire code has been revamped due to it being virtually impossible to get from the top floor down to the bottom in a very tall building quickly enough.
Lifts can be used to get people safely down onto the ground. Not any lift can be used for this however, you must make sure that your elevator is shielded and protected.
Evacuation Plan
The uniform fire safety plan states that you should have an evacuation plan clearly set out. Choose a few meeting points and make sure that these are well publicized.
Fire Fighting
The uniform fire safety plan also suggests that fire suppression devices are used to help stop the fire from spreading. There are lots of different types of suppression system and the best one for your needs will normally depend on the equipment in the room.
- Sprinklers are great to stop a fire, however they could end up causing lots of damage to electrical equipment. Old fire systems are often a danger to the environment, newer systems are much kinder to the environment and also cheaper.
- When choosing a fire suppression system, first spend time considering the types of fire that you are likely to experience in your business. For example, are electrical or gas fires more likely to occur? Once you have found this out you can plan accordingly.
- A fire alarm is also mandatory in many types of buildings, ideally this should be an alarm which rings straight to the police station or another companies call center.
Local States
States are free to set their own codes and adjust the uniform fire safety system however they see fit. Search on the Internet or in your local library to find out which of the uniform fire safety rules apply to you and your business.
Fire is something that deserves to be taken very seriously. It’s simply impossible to waste any time or to spend too much time planning what you should do during a fire. You really do owe it to your employees to get them out safely.
