Login Error
Close
Upgrade Your Toilet with a Hand Held Bidet Sprayer
by DoItYourself Staff
what you'll need
  • Teflon tape
  • Pair of pliers
  • Wall bracket
  • Long PVC hose
  • One-way valve
  • Sprayer with trigger
  • Standard T-adapter
  • Adjustable wrench
A hand held bidet sprayer is a very useful upgrade for you toilet and bathroom area. It enhances better health for both men and women, even though many people, especially in the United States of America, think that bidets are used only by women. This misconception was started by U.S. soldiers after World War II. Most often, bidet sprayers are installed in small bathrooms where there is not enough space to install an ordinary bidet.
The idea of bidet sprayers originated from Asian countries such as Japan and India. They do not make use of the traditional toilet paper but utilize bidet sprayers instead. Bidet sprayers are mostly used to clean the genital and rectal areas, but they can also help you to refresh yourself and disinfect sensitive parts of your body after a surgical operation.
Step 1 – Turning Off the Water Supply and Getting Started
Switch off the power supply right at the start, then take away the water valve off the water line in the wall.
Step 2 – Fixing the T-valve with Teflon Tape
Fix the T-valve into the water line and seal it with Teflon tape to avoid leakages. Keep in mind that if your water line is a pipe made of unthreaded brass, you need to put a compression nut first before adjusting the valve.
Step 3 – Fixing the Bracket and The Sprayer
Fasten the bracket against the wall as a holder for the bidet sprayer. Now connect the nozzle of the sprayer to the PVC hose. It is important that the sprayer is equipped with a pressure and flow control button. Make sure to place the black rubber washer onto the metal mesh before you fix the hose and tighten it.
Step 4 – Joining the Water Line With the T-valve
Join the water line of the toilet back with the T-valve and seal it again with Teflon tape.
Step 5 – Linking the Bidet Sprayer to the T-valve
Attach the hand bidet sprayer to the other end of the T-valve and use some tape to seal it. Make sure to put the black rubber washer first. You can utilize a pair of pliers or an adjustable wrench to confirm that the washer is tightened securely.
Step 6 – Turning the Water Supply Back On and Checking For Leakages
Switch on the water supply and check whether the unit is working properly. Inspect the area for any leakages and tighten if necessary.
The advantages of installing a hand held bidet sprayer to your toilet are many; you do not need to call a professional plumber to do the job for you. You can install the upgrade yourself without paying a lot of money. The bidet sprayer has the same functions of a full-size bidet unit like that found in several large and luxurious houses. Hundreds and thousands of people claim to make regular use of a bidet or a hand held bidet sprayer.
 forum activity
