Use a Portable Pressure Washer to Clean Siding
A portable pressure washer is a device that can make cleaning your siding much easier. You could potentially purchase one of these tools or rent it from a rental store. Here are a few things to consider about using a portable pressure washer to clean your siding.
Types of Portable Pressure Washer
Portable pressure washers come in many different varieties. You could use a gas or an electric pressure washer for this job. When you utilize a gas pressure washer, you will be able to generate more power than you would with an electric. Electric power washers also require you to work where there is an electrical outlet close by. With this type of device, you can hook up a traditional garden hose to it to supply it with water. You can then spray the side of the house with a strong stream of water.
Types of Siding
In most cases, you should be able to use a portable pressure washer on your siding regardless of what type of siding you have. If you have brick siding, you should be able to spray it without any issues. It is durable enough to stand up to any setting on the pressure washer without any problems. If you have stucco siding, you need to be careful with the pressure washer, but you can still use it. When you are cleaning stucco siding, you want to make sure that you do not use the most powerful setting. Most of the time, you will need to put it on the medium setting so that you can avoid putting a hole in the stucco. If you have vinyl or wood siding, you should also be able to use the pressure washer without any issues.
Detergent
When you perform this job, you may want to utilize a detergent to help clean the siding. There are commercial detergents that you can buy for this project. Many times, you can purchase them at a paint store or at a local home improvement store. These detergents can be poured into a bucket and sucked up into the power washer by a hose.
If you do not want to purchase detergent, you can potentially make your own. Many people will use laundry detergent or dishwashing detergent and other household chemicals mixed with water. You should most likely stay away from bleach or bleach-based cleaners so that you do not damage the color of the siding. Detergent will help break up the debris and dirt that have been building up on the side of your house for years.
Spraying the House
When you utilize a pressure washer, you need to make sure that you use the proper technique. When spraying the side of your house, you should do so at a 45-degree angle. You want to make sure to use a constant stream of water instead of starting and stopping frequently. Make sure to do the entire side of the house so that it cleans it uniformly.
