Use an Auger Anchor to Secure Items to the Ground
An auger anchor is something that is used to help keep items secured to the ground. You will find that these anchors are easy to use and will help you to keep your outdoor items from blowing away in the wind. It is important for you to understand the different ways that you can use an auger anchor and the best way that you can use it as well as the other options that you have and why an auger anchor is effective.
Why Auger Anchors?
Tie downs are something that you will need to use whenever you have something that may easily blow away in the wind. This can be used for things such as tarps, grills, tables or other types of patio furniture or even manufactured homes. Regardless of the area that you live in and no matter how strong the winds may be from time to time, you will find that these anchors are great for you to be able to have the opportunity to keep things where you want them to be for as long as you need them to be there. It is important that you know the necessary requirements that are needed for these anchors and what you will need to do in order to use them properly.
Types of Tie Downs
It is important that you understand the different types of anchors and tie downs that are out there and what they should be used for so that you will be able to understand what you can get out of each variety. For example, if you have an older manufactured home, then a vertical or over-the-top tie down is something that is going to help to compensate any type of uplift force that you will come into contact with. Any frame or diagonal tie downs will be needed so that you can help to compensate for any uplift or lateral forces. If you have a manufactured home that is singlewide, then you will find that both types of tie downs will be necessary. However, a doublewide will only need a diagonal tie.
Anchors
Now that you have a basic understanding of tie downs, you can understand what anchors are and why you would need them. The anchors that you choose will have a lot to do with the soil conditions that you are working with. An auger anchor is something that is designed to work with both soft and hard soil. These anchors are pinned into the ground with a steel steak. You can then pour concrete if needed. An auger anchor is versatile and will be able to work with most types of conditions that you have. However, if you are working with a coral or rock base, then a rock anchor is what you should use.
Soil Type
Soil type is something that is important whenever you are deciding what type of anchor or tie down that you use. However, there is an auger anchor available that will be able to work in any type of soil condition that you have.
