Login Error
Close
Use Sustainable Technology to Transform Your Vegetable Garden
by DoItYourself Staff
If you have already taken the measures to start your own vegetable garden, the next step is to incorporate sustainable technology to make it is self sufficient as possible. By making your vegetable garden sustainable, you are reducing your need for outside materials including soil, water and other resources. Sustainability in the vegetable garden is about technique just as it is about technology. Good gardening practices will not only increase the produce, but they will help to reduce any negative effects on the environment. Some of the sustainable practices you can do include composting, installing a rain barrel, farming organically and saving seeds. When used together, you will reduce your overall dependency and become a truly sustainable gardener.
Composting
Composting, contrary to popular belief, does not necessarily require an abundance of space to do effectively. You have to have a little knowledge and the will to keep up with it, but it can be done with relatively little space. Composting is the process of turning organic waste into nutrient-rich soil to distribute over the garden. Not only does it reduce the amount of waste you send to the landfill, but it returns much-needed minerals to the soil. The vegetables in your garden will thrive with good compost. Grass clippings, leaves, twigs, cuttings from flowers and shrubs and all food waste with the exception of greasy, lard-based foods can go onto the compost pile. In the proper amounts and with the right aeration, this waste, over time, will become rich compost. It will give your garden new life. If you have the space, you can do it in several large piles, but that is not necessary. It can be done directly in the ground in small holes as well as in small piles.
Rain Barrels
Rather than let all of that natural rain simply wash down from your gutters into the storm drain, installing rain barrels for the purpose of storing it and using it in your garden is a highly sustainable method for gardening. The biggest difference this will make is on your quarterly water bill. You can hook a spigot and a hose right up to the bottom of a rain barrel, and as it fills it provides you with an ample water supply with which to water your vegetables. It has the doubly positive effect of reducing the amount of water that reaches the storm drain. For this your municipality will be thankful.
Organic Gardening
Vegetable gardeners should strive to be organic gardeners. There are numerous ways to protect your vegetables against pests and disease without the aid of chemical fertilizers. The use of those not only puts it in the ground water, but it can poison the native soil around your home. Companion planting, crop alternating and organic methods for pest control are all easily learned and applicable. You will protect the life of the soil as well as grow tasty organic produce.
Seed Saving
This is a sustainable method that usually takes some time to learn. Harvesting seeds from grown vegetables and fruits often requires a few steps. It is not always a matter of picking a ripe specimen and removing the seeds. That being said, with a little practice it will become routine. By saving seed you avoid having to return to the nursery year after year and purchase new seeds. This is an age old process. It is how agriculture propagated itself over centuries. Thus, there is every reason to believe that it can work today.
Sustainable farming techniques are easy to learn and only require a little planning. You will have to put in some work, but the rewards are well worth it. In time, your vegetable garden will be transformed into a small slice of organic paradise.
 forum activity
