Login Error
Close
Using a Crown Molding Jig
by DoItYourself Staff
what you'll need
  • Crown molding jig
  • Wood or similar material for template
The use of a crown molding jig can make all the difference when designing a room. The elegance and unique design that crown molding provides are simply incomparable. The classic feel that crown molding provides a room is the same emphasis that a picture or painting frame can give a photograph or work of art. Since the use of crown molding has gained considerable attention throughout the years, people now have more options in terms of design and materials. For every space and theme, there’s surely a crown molding that can fit. Small crown molding profiles are ideal for cabinetry and different furniture whereas the larger types are used as components of an architectural landscape.
There more important question now is: how come most do it yourself aficionados don’t personally install crown molding? The case is, crown molding installation has not been an easy personal home improvement project. People usually find it hard to cut compound angles, tailor fit materials, check and note corners, etc. The main problem is that most people have a hard time getting and cutting the right angles for the crown molding. Installation is rather easy. It’s the cutting part which makes everyone do a double take. Fortunately for technological developments, the latest crown molding jig equipment out in the market are more relatively easy to use. The subsequent sections provide an overview on how to set up and use a crown molding jig.
Step 1: Create Template
Prior to setting up the crown molding jig, you should create a plain crosscut on the saw. You’ll have a 2 foot long piece to use as the template of the crown molding. Usually a single plane saw is used. It’s either the old miter saw or a radial arm saw.
Step 2: Position Template
To properly set up the molding jig, position the template piece in the crown molding jig. The edge of the jig should be held up. The position of the jig’s edge should be strictly followed. To make a single cut of crown molding, the template’s bottom should be positioned very closely to the blade.
Note: The position of the crown molding jig against the wall should also be carefully considered. Most crown molding jigs are positioned around 52 degrees against the wall.
Step 3: Adjust Fence
In order to flush the top and bottom of the molding’s end, the fence should be adjusted. A 90 degree angle should form at when the sliding fence meets the molding.
Step 4: Tighten Knobs
To maintain the setting, the jig’s knobs should be tightened. Make sure that both knobs are adjusted accordingly. The knob adjustment for a crown molding jig depends on the kind of jig used. Different brand names have different adjustments. After this, you’ll now be able to make the cuts.
Step 5: Understanding the Cuts
A crowd molding project usually only needs five types of cuts. The cuts are either made inside or outside the corner, right or left or a simple splice tying two piece of crown molding. To determine what kind of cut you will make, try standing inside a rectangular room. From the center, try observing the four corners. An “inside left” crown molding is used on the left corner whereas for rooms with alcoves, an outside corner or an L-shape crown molding will be needed. To make sure that you achieve the right angle, try using a true angle protractor. The measure you get should be divided in half. This will give you the setting you need for your cutter.
 forum activity
