Using Ceiling Fans Alongside Air Conditioning
Many people know that ceiling fans can help keep a house cooler. However, not everyone realizes that in combination with air conditioning, a ceiling fan can reduce energy costs and keep your home cool and comfortable. So how is it that you can use a ceiling fan in conjunction with air conditioning to save energy costs?
Air Circulation
A ceiling fan also helps keeps a house cool for the simple reason that it creates a cool breeze. When people walk by the breeze created by the ceiling fan, it causes a cooling effect. Because you feel cooler, it's possible to set the thermostat at a higher temperature without becoming overheated. Basically, a cool breeze keeps people's temperatures down because the air evaporates moisture on the skin.
Shopping for a Ceiling Fan
When selecting a ceiling fan, the model you select depends on the size of the room in which it will be placed. If you have a large room, make sure you purchase a large enough fan so that it can effectively cool the area. Luckily, ceiling fans are quite affordable. Although there are expensive ones on the market, many ceiling fans come at an affordable price and work very well.
Find a ceiling fan that will work well for your home. If you take some time before making a final purchase and do some research, it will be much easier to find the right fan for a price you can live with. Stay away from cheaper models, as they may not last long enough to produce the energy savings you are looking for.
Ceiling Fan Types
Simple ceiling fans aren't too fancy. You turn them on with a pull cord or a light switch. These ceiling fans are usually less expensive, and suit more traditional decors.
Modern ceiling fans offer homeowners extra features, such as dimmers or a remote control. A remote control can be used for various purposes, including to turn the light on or change the speed of the blades. It's possible to purchase a universal ceiling fan remote if your current ceiling fan doesn't have one.
Different ceiling fans offer different speed settings as well. The standard setting is three speeds, however, there are models that have more than three speed settings.
Some ceiling fans are made for kitchens, bathrooms, and other areas that experience a lot of moisture on a regular basis. Fans are needed in these rooms to promote proper air circulation and keep moisture from accumulating on the walls and surfaces of the room. Spas and saunas also require special ceiling fans to circulate the air. The blades of these fans are constructed to hold up to rust and wet conditions.
Outdoor ceiling fans are specially designed to hold up to harsh weather conditions. These ceiling fans make a great addition to an outdoor space, and are often used to cool a hot patio or backyard deck.
Ceiling fans also come in a wide variety of different styles. Some have more blades than others, and come in different sizes. The type of fan you choose depends on the décor of your home and personal preference.
