Using Embossing Leveler
what you'll need
- Scraper blade
- Flat-edged trowel
- Embossing leveler
In case you’re not familiar with embossing leveler, this is a compound that looks like mortar, and you can utilize it for new flooring installation. Embossing leveler will work as an underlayment, when you install new flooring to a room. The aim of an embossing leveler is to reduce any effects which are the results of seams, depressions and the quality of the existing floor, when you install the new floor on top of it. Keep in mind that if you do not apply embossing leveler over the old floor’s design, it will appear through the surface of your new floor as well, especially if both the old and new floors are made of vinyl.
Step 1 – Identifying the Flooring Material
First of all, select the material for your new flooring. You can choose wood, vinyl and tile among others. You will not have any trouble using embossing leveler when installing new wooden flooring. However, if the old flooring is made of vinyl and you would like to install tiles made from ceramic, slate or porcelain on it, make sure that you get rid of the old vinyl floor first. This is because the tiles will crack and get damaged, if you install them over vinyl flooring.
Step 2 – Choosing the Embossing Leveler
There are many different types of embossing leveler. Select one depending on what you want to use it for. Generally speaking, a typical embossing leveler is a dry compound based on Portland cement, that has urethane or acrylic ingredients added to the mixture. There are other types of embossing leveler that have latex resin. You can also buy such embossing leveler in a canned pre-mixed form.
If you are using the powdered version, make use that you mix it well in order to obtain the right consistency. Read the instructions on the package to know what it is used for and choose the embossing leveler which is right for you.
Step 3 – Applying the Embossing Leveler
Make sure that you have enough time, because you need to apply the embossing leveler at a minimum of 24 hours to allow it to cure before you start the new flooring installation project. The drying process will take approximately between 20 and 30 minutes. Keep in mind that you should let it harden fully, so that you will not find it difficult to trim it. Apply the embossing leveler onto the floor with a flat-edged trowel, at an angle of about 45 degrees. Use the trowel again to remove any excess leveler, and make sure that you have filled every indentation and pattern of the old floor.
Make sure that you work at a fast pace, keeping in mind that embossing leveler will have already started to dry after 10 minutes. There will be no need to trim or sand the embossing leveler, if you are using a flat-edged trowel skilfully enough. However, many people will find that the surface of the leveler is uneven after it has dried thoroughly. In this case, smooth the uneven areas, by using a scraper blade.
