Login Error
Close
Using Fireproof Storage Cabinets to Keep Valuables Secure
by DoItYourself Staff
To protect sensitive documents, many business and homeowners can benefit from fireproof storage cabinets. There are different types of fireproof storage cabinets available, but the most common ones are those that are made of steel. The steel used in making them is at least 18 gauge in thickness. They are provided with vents to let the smoke out in case of a fire. Other metals that conform with NFPA Code 30 and OSHA stipulations are also commonly used.
These storage cabinets can be expensive because of the pricier metals that are used in their manufacture and their general structuring. You could expect to pay between $2,000 and $4,000 depending on the kind of cabinet you are looking for. The number of shelves in the cabinet also influences the price.
The Cabinet's Construction
Having an idea of how fireproof storage cabinets are made may set your mind at east over how worth it they are. Many feature a double wall construction, with fire and heat resistant materials in between. Many even have a poured cement insulating layer. They typically feature a tongue-and-groove construction to hold out hot gasses and flames, and they feature a minimum thickness of sheet metal to minimize heat conducted inside.
If you are questioning whether or not a fireproof cabinet belongs in your home or business, consider some of the advantages.
Advantages of Fire Resistant Storage Cabinets
Everybody, from the highest business executive to the simplest home owner, has some sort of document or object that is priceless to them, whether it is important business paper work, insurance paperwork or a personal will. Fireproof storage cabinets not only protect against fire, but also often deter theft and prevent or minimize other disasters.
Some might consider them a large inconvenience, especially for paperwork that is in regular use, but this is less and less of a concern as computer backups of all information is more common.
Fireproof storage cabinets are also used for storing flammable items, especially flammable liquids, usually in factories and storehouses.
 forum activity
