Login Error
Close
Using Home Equity for Home Improvements: When to Avoid It
by DoItYourself Staff
Home improvements can be expensive, particularly if the modifications needed are significant. There are several options to get the financial assistance you need for these improvements, one of which is using your home equity. However, it is important to remember that there are certain situations when using your home equity for home improvements is detrimental.
High Interest Rates
Interest rates on home equity loans fluctuate. If the interest rates are high it is not advantageous to use equity to make any improvements. Once the market interest is too high it is best to delay your plans until the interest rates are lower.
Moving Soon
If you have plans to move it is not recommended to use your home equity to make home improvements. This is especially true in the event that the market value of your property might go down. This can mean that you have to wait before you can sell your home. In this regard, it is a good idea to delay any home modifications until you are definite that you are not moving any time soon.
You also need to be careful that your home does not have an upside down mortgage. This simply means that your property is over-encumbered with mortgages. Using equity to make home improvements to increase the value of the property will not work.
Increasing the Value of Your Home
Although home improvements may increase the value of your home, it is not guaranteed. If you plan to use your equity for any modifications to increase the value of your house it is imperative to do some research. Remember that some improvements may not add value to your property.
In this regard, choose improvements that will increase the value of your house. Repainting or changing the carpets will not add value. However, extending the living space, improving insulation, plumbing, electrical wiring, or installing hardwood floorings can increase the value of your house, making it a more viable idea to use your home equity for home improvements.
Possibility of Foreclosure
Most homeowners will use their equity to make improvements on their homes to increase its value. However, remember that in a home equity loan your house is the collateral. In this regard, any delays on payments may cost you your home or the possibility of foreclosure. If you do not have the financial stability to incur additional payments, using your home equity for home improvements should be avoided, even if to increase the value of your property.
 forum activity
