Login Error
Close
Using Latex Paint on Kitchen Cabinets
by DoItYourself Staff
Latex paint is a fast-drying paint holding pigment suspended within the acrylic polymer emulsion. These latex paints can be diluted with water. However, it becomes water-resistant once dried up. Depending on the paint quantity, if it is diluted in water or other solvents, the finish latex painting can look like oil or watercolor painting. Because of latex paints remarkable characteristics, it is a favorite paint to apply at home, particularly on kitchen cabinets. It gives an exceptional graceful feel and easy to clean once its surface becomes dirty.
Latex paints are also very affordable, so you will not spend more on buying a paint that will beautify your kitchen cabinets and other furniture that needs repainting. Ample amount of money is sufficient enough for painting your kitchen cabinets.
Techniques and Latex Paint Considerations
Latex paints are normally thinned with water then utilized as washes in the mode of watercolor paints. However, these washes are not re-hydratable if already dried. Because of this, latex paints do not offer themselves with color lifting techniques similar to the gum Arabic-based watercolor-like paints.
Normally, latex paints are used in matte or high gloss finishes. While with oils, particle size and pigment amounts alter the latex paint sheen. Similarly, matting agents are added to dim the finish. Varnishes or topcoats are applied as well to alter sheen. You can simply apply these latex paint considerations to ensure better results for your kitchen cabinets painting.
Latex Paint Removal Method
Once dry, latex paint is commonly non-removable. Mild solvents or water don’t re-solubilize it. Although, isopropyl alcohol lifts some unmarked paint films off. Acetone and toluene remove latex paint films. However, they don’t lift paint blemishes very well and they are not careful. The exploit of a solvent to get rid of latex paint will effect in removal of the entire paint layers and other paint additives.
The viscosity of latex paint is effectively reduced through using suitable extenders which preserve the truthfulness of the latex paint film. There are available retarders to extend workability time to boost color blending capability.
Latex Paint on Your Kitchen Cabinets
Sanding the kitchen cabinets to be painted is a must to smooth the surface. This is particularly significant for cabinets which are very glossy. Extremely glossed finishes make it difficult for the latex paint to stick.
You also need to apply an oil-based primer to the cabinets. Employ a brush or roller to prime them then let the kitchen cabinets dry before painting. Put on a second coating of latex paint after initial coating dried up completely.
Latex paint works great on surfaces formerly painted with flat oil based or latex paints. Latex paint can even be utilized on unpainted masonry or unprimed drywall. Nevertheless, latex typically does not stick properly to high-gloss finishes.  Although, it can be applied on wallpapers, there is a hazard that the water within the paint may trigger the paper to be removed from the wall. Due to its water content, latex paint will also trigger bare steel to gain rust, as well as raise the raw wood’s grain. Nonetheless, latex paints are the best to be used particularly if you know how to apply it properly and it is still the most favorite choice of paint for kitchen furniture and cabinets.
 forum activity
