Using Lavender to Repel Mosquitoes
Lavender is a flowering, fragrant herb that belongs to the mint family Lamiacea. Lavenders are native to the Mediterranean region and southeast regions of India. The oil extracted from the blue-violet flowers has both medicinal and antiseptic uses.
Lavender oil has a calming scent and widely used in the medicines for reducing tension, migraine, anxiety, and depression. Its aroma reduces nerve exhaustion and also induces sleep. This oil is used as a remedy for muscular pain, and widely used in the treatment of respiratory and urinary disorders. Lavender oil is also used for the treatment of hypertension and digestive problems. Another important use is as a repellant against harmful insects.
Using Lavender Oil to Repel Mosquitoes
Lavenders are widely used as a repellent against mosquitoes and other insects. The advantage of using lavender oil over other chemical repellants is that it is completely natural and also has a sleep-inducing effect. It also nourishes the skin with no side-effects unlike other synthetic repellants. Moreover, the aroma is also pleasant when compared to the strong-smelling mosquito repellant creams.
To stay safe from mosquitoes, you can directly apply the oil to the ankles, wrist, or feet. The mode of application is similar to that of a perfume. Mix the lavender oil with aqueous cream and then apply to the desired parts for more sensitive skin.
Mixing lavender oil with citronella and eucalyptus oils and then spraying this mixture is an effective means to repel mosquitoes. This mixture is also used in the candle production. This herb can also be planted in your garden as it keeps the surrounding areas of the house free from mosquitoes and other unwanted insects.
