Login Error
Close
Using Solar Power for Aquaponics
by DoItYourself Staff
Solar power is being used in an increasing number of projects around the world. To the environmentally conscious, this technology has immense benefits to offer. Considering the growing strain on our environment, it is time we all considered solar power as a practical option. Aquaponics or the practice of combining aquaculture and hydroponics is fast growing to become one of the preferred means of producing crops. The integration of solar power and aquaponics can reap huge rewards for the user.
How to Incorporate Solar Power in Your Aquaponics System
Your first step must be to decide on the size and capacity you want in your solar panel. Depending on the scale of your aquaponics practice, there are a variety of solar panels you can purchase. The configurations can also vary according to your individual needs. You can use solar power in a variety of ways in an aquaponic setup.
Temperature regulation in a fish tank is of high importance. Water that is at the right temperature can contribute to the healthy growth of your fish crop. You can use solar power to heat up the water to the desired temperature. You can also use solar powered heaters or air conditioners to maintain the desired temperature in your greenhouse. The pumps that supply water to the hydroponic bed and the fish tank can also be powered with solar energy.
Benefits of Solar Power for Aquaponics
Solar power has widespread benefits for all its users. You can save money on electricity and also be a big help to the environment. A large-scale commercial aquaponic system will require a large amount of power. You can save this expense and also conserve a significant amount of energy by converting to solar power. The solar panels you install require minimal maintenance and care. As a result, you can cut down on installation and repair costs in addition to reducing labor costs. Solar panels are sturdy and long-lasting, so you can be assured of making a good investment.
Solar energy provides high quality results. You can also vary the intensity of your lighting or heating requirements from time to time. You can incorporate solar power in your aquaponics environment irrespective of the location you are at. There are no emissions to worry about. Solar power adds to the organic appeal of aquaponics.
Drawbacks of Solar Power for Aquaponics
The biggest drawback of solar power is the reliability on sunlight. If you live in a colder environment or if there are several rainy days in succession, you may not be supplied with enough solar power to meet your needs. However, the good news is that with advancements in solar technology, these drawbacks are being swiftly mitigated.
For reliable operation of the solar system, you must invest in a backup battery system to store excess solar energy. This way, you will always have a supply of electricity for your needs. In case of an interrupted power supply, you may be at danger of losing your fish crop and also your plant crop.
 forum activity
