Login Error
Close
Utilize Space With a Pantry Door Shelf
by DoItYourself Staff
If you look inside many pantries you’ll probably notice a severe lack of space, however by using a pantry door shelf, you can save a surprising amount of room in your pantry. Although you may have hundreds of spices and other cooking tools and ingredients, you can organize your pantry space a lot more efficiently with the use of a door shelf.
A pantry door shelf saves space is by adding attachable shelves onto the actual door of the pantry. This can save a surprising amount of room because small items such as spices or herbs can be placed easily on these shelves.
You can find a pantry door shelf in many places now and companies have found a way to appeal to almost any budget. If you are running on a tight budget but want to maximize the space in your pantry, you should look for a metal pantry door shelf. These tend to be cheaper and hold fewer items than a wood pantry door shelf which is more expensive, but can look more professional while holding more supplies.
 forum activity
