Login Error
Close
Variations of Island Cooktops
by DoItYourself Staff
Island cooktops are a fantastic investment for your entire home and it can make your kitchen look much more modern. A separate cooktop and oven is very fashionable but it doesn't have to cost you a fortune. Your kitchen should be able to benefit from this investment and you will be able to enjoy it too.
Space
When you are considering the type of island cooktop you want to install you will first need to think about the space that you have available. These types of cooktops require space differently to a range because the two units can be seperate. It's also important to make sure that you have enough space to fit proper ventilation which can then extract all of the fumes and smells from your kitchen.
Many island kitchens are making use of downdraft ventilators as these don't need any hood over the cooktop. These types of vents can be installed next to the cooktop and some island cooktops come with built in downdraft ventilators. Venting your cooktop isn't as difficult as you might imagine and there will always be a way to vent your cooktop.
Types of Island Cooktops
When choosing different types of island cooktops you have a number of different options. There are gas, electric, halogen, induction or LPG cooktops. Any of these cooktops are suitable for island kitchens, but some may be more suitable in certain cases. Learning about appliance installation will help you to understand the differences between various types of cooktops.
Gas Cooktops
A gas cooktop is a very popular option and these can either use liquid propane or natural gas from the mains. If you have natural gas available then this is normally the fuel of choice. Even if you choose gas you will still need an electricity supply to ignite the gas. This means that to use a gas cooker you will need a normal 120V power supply and gas supply, if this is possible with your island kitchen then it makes an ideal island cooktop.
Electrical Cooktops
There are many different types of electrical cooktops which are very popular. Electricity is a popular fuel because there aren't any flames and it's often seen as a safer option. The controls are also much easier and can be compared to the simplicity of microwave cookers.
An induction cooker is the most expensive type of electric cooker which offers the same level of control as gas cookers. To use any form of electrical cooktop in your island kitchen you will need a dedicated power supply, talk to an electrician to get this hooked up.
Size
When you have decided on the fuel you want to use to cook on you will then need to think about the size of cooktop that you want to install. Cooktops are available in all sorts of different sizes which are suitable for every size of kitchen.
Cleaning
It's also worth thinking about how easy it is to clean your cooktop, although you won't be cleaning it when it's brand new it is important after a while. Choosing a cooktop which is easy to keep clean should save you lots of time in the long run.
 forum activity
