Ventless fireplaces operate without the need for a chimney or flue system. This means vent free gas fireplace models ideal when large-scale installation projects or not possible.
How ventless fireplaces work
Ventless fireplaces operate using natural gas in most cases. Whether it’s propane, ethanol or another combustion agent, ventless gas fireplaces do not require an emission system because they burn gas and not wood. This means their emissions are rather low, but some models can create concerns about oxygen displacement nonetheless.
While ventless fireplaces do come in different designs, most have a few traits in common. Vent free fireplaces, for example, will require a line for the fuel supply. They will also have an enclosure to house the fire. Some ventless fireplaces also rely on ceramic logs and sand to give a more realistic appearance.
Uses for ventless fireplaces
Ventless fireplaces serve two major purposes in homes. They are:
- Heating, which can hinge a lot on a vent free gas fireplace design. Some models generate more heat than others;
- Aesthetics, which is a driving force for the purchase of these models by many. Some ventless fireplaces produce a visually pleasing fire.
Questions of a Do It Yourself nature should be submitted to our
