Login Error
Close
Vinyl Garage Door Trim: Installation Tips
by DoItYourself Staff
You can change the outward appearance of your garage by installing vinyl garage door trim. This can also help seal the smaller cracks where your trim come together, preventing bugs and other pest from getting into your building.
Have the Correct Trimming Tools on Hand
There are a number of tools you will want on hand while doing vinyl garage door trim installation. Your main tools should be a snap hole punch, a nail hole punch and a vinyl unlocking tool used to remove pieces that have been snapped into place already.
Securing the Trim Runners
All types of vinyl garage door trim and house trim involve a series of runners to hold the vinyl into place. Some are mounted to clips, while others clip onto an actual rail that spans the length of your mounting area.
Proper Cutting of Panels
Once you cut a vinyl garage door trim panel, there is no turning back. Be sure that you take proper measurements to avoid undercutting or over-cutting your pieces.
Getting Corners Flush and Applying Sealants
All the corners of your vinyl garage door trim should be joined at a 45 degree angle, and sealed with a rubber sealant to prevent leaking in heavy weather conditions. Water that gets behind the trimming can grow mold and other wood damaging effects over long periods of exposure.
 forum activity
