Login Error
Close
Vinyl Gutters vs Seamless Gutters
by DoItYourself Staff
Most homeowners know the importance of gutters in keeping their homes maintained, whether they have vinyl gutters or seamless gutters. A clogged or damaged gutter system poses potential dangers to the house, especially during rainy months. When the waterway is congested, the water tends to overflow into the house’s attic or into the living area of the house. So before installing a new gutter system for your house, be sure to choose the best type for your particular needs. Two of the most common types of gutters are vinyl gutters and seamless gutters. But what makes each type different from the other? Let us take a closer look at the pros and cons of each gutter type.
Vinyl Gutters- Pros
Vinyl rain gutters are arguably one of the most popular types in the market right now. There are many advantages to using vinyl gutters. When it comes to installation, vinyl gutters are the easiest of all types, since their light weight makes them easy to handle. Moreover, vinyl gutters have sections that have already been pre-cut. Unlike steel, vinyl is a material that does not rust quickly. Thus, you don’t have to maintain it regularly. It doesn’t have to be painted either. All you have to do is clean out the debris often in order to avoid clogging. Finally, vinyl gutters are the cheapest on the market right now. If you are on a tight budget, then vinyl gutters are the ideal choice.
Cons
Vinyl gutters may not be suitable for your house if you live in a hot, sunny area. When exposed to scorching heat, vinyl material may crack and eventually deteriorate. Vinyl can also warp easily, especially when exposed to heavy amounts of rain. Moreover, debris that has collected can damage the gutter easily if you fail to unclog it regularly.
Seamless Gutters- Pros
Unlike traditional gutter system, seamless gutters are far more strong and durable. This is due to the types of materials seamless gutters are made of, such as galvanized steel, aluminum, copper, and even vinyl. Compared to other types of gutters, seamless gutters can last for years. And unlike other guttering systems, seamless gutters have seams only in the corner or downspout areas, which reduces the possibility of leakage. Seamless gutters are made up of multiple pieces, which make them stronger. If a section fails, it will not endanger the entire unit. Another beneficial aspect is that seamless gutters can come in a wide variety of colors. Thus, you will be able to choose the right color that blends well with the exterior of your home.
Cons
Seamless gutters are a lot more expensive compared to other guttering systems. If you are conscious about your budget, you may have to choose a less expensive type of gutters. Moreover, seamless gutters are quite difficult to install. You may need to consult with experts.
Before deciding on the right type of gutter to purchase, make sure that you weigh all the factors carefully. It is worth reading online reviews to understand various experiences with each gutter type.
 forum activity
